What to do if your bike has overheated?
Postby Stereo » Tue May 12, 2009 2:11 pm
Hi guys, Ive got a track bike in the garage which if I havent used recently will run for a few minutes every second weekend...
Anyways, last weekend I was busy doing something else and got so used to the sound of it running (I usually let it get up to 95 degrees before switching it off again) that I completely forgot to switch it off....
Anyways to cut a short story long, I suddenly realised that I had left the bike on.... Ran in, it was at 132 degrees, steam was pissing out all over the place.
What is my recommended action to make sure the bike doesnt suffer any long term effects? Do I just fill up the radiator and keep going or do I need to do a full lube job?
Re: What to do if your bike has overheated?
Postby Stace » Tue May 12, 2009 2:16 pm
I'd say just refill the coolant to start with and check it out to make sure nothing else has gone amiss. If it keeps getting hot and you know the radiator is fine, check the thermastat is working and there are no air locks in the cooling system.
I'm making the assumption the head gasket is ok by the way. No water in oil or oil in water etc
Failing that use a big hammer ;) Or just trade it in on a Kawasaki :kuda:
Stace
Team Bolt
Team Bolt
Postby Stereo » Tue May 12, 2009 3:37 pm
Thanks Stace.
Ill try that, hoping nothing is wrong with it....
Postby Wattie » Tue May 12, 2009 7:00 pm
put the fan back on it, and make sure the thermostat is good. no way it should get that hot. even idling still. uless its air cooled. which i kinda doubt seeings you talking about refilling the coolant :lol:
Postby lifeofcrimeguy » Tue May 12, 2009 9:24 pm
On a hot day mine will hit 117 waiting at lights, no cars in front. dont know if it go higher because i turned it off the first time and the light went green the second time. Doing 60k in 6th the rest of the way home... chug chug chug.
See here, young man,
From Walgett to the sea,
-- Banjo Paterson
LMFAO
lifeofcrimeguy
Postby Six Addict » Tue May 12, 2009 10:03 pm
shouldnt get that hot jason... highest ive seen on mine is about 106...
my coolant needs a bit of a top up but the cold weather is helping me out for a while!!! :lol:
Postby lifeofcrimeguy » Tue May 12, 2009 10:21 pm
Yeah, mine used to only hit 106, then it was 110, then it was 115 and red light time then 117. only on the hottest days tho
-- Banjo Paterson
LMFAO
lifeofcrimeguy
Postby photomike666 » Wed May 13, 2009 12:36 pm
With the old air cool bikes, when they got too hot, we just used to piss on them. Perhaps this is suitable treatment for the spewie too?
Postby Stace » Wed May 13, 2009 1:15 pm
photomike666 wrote:With the old air cool bikes, when they got too hot, we just used to piss on them. Perhaps this is suitable treatment for the spewie too?
I agree, Actually that should be done to all suzuki's every thousand km or so :twisted:
Stace
Team Bolt
Team Bolt
Postby Stereo » Thu May 14, 2009 4:07 pm
Wattie wrote:put the fan back on it, and make sure the thermostat is good. no way it should get that hot. even idling still. uless its air cooled. which i kinda doubt seeings you talking about refilling the coolant :lol:
It was sitting in the garage without any airflow, for bloomin ages.... I dont think the thermostat is broken because it really did seem very hot, 132 would surprise with me... the fan was running full boar just wasnt getting enough air to cool it down I think...
Postby Bogan » Thu May 14, 2009 4:11 pm
Tony
I have become race...
Bogan
Users browsing this forum: No registered users and 29 guests
