Z1000 airbox mod Q
Saki
Z1000 airbox mod Q
Post by Saki »
Hey guys,
Well my BMC turned up today so install that now. However i wanted to do the airbox mod while its all apart. I have a downloaded map which i intend on getting run on the dyno and having a custom one made so that no issue.
Anyway, if i do the airbox mod with the new filter is it going to send the whole thing a bit crazy with too much air, as in will i need to get it tuned right away or will it pretty much be ok as is.
Basically wat i am ask is, should i hack it up now and chuck it together with the expectation that it iwll be of benefit, or should i wait when it comes closer to the date of getting it run on the dyno to have the custom map because it will cause problems before hand ?
RichB
Re: Z1000 airbox mod Q
Post by RichB »
Depends on how serious the mod to the airbox is and how the bike is stock/with your PC3 now i.e. lean or rich. i.e. if its a bit rich now it would even things out. But if it's already lean then it will worsen the situation. In the end it won't be crazy different, but will probably have a fluffy effect to the throttle if you get it wrong, so not as crisp as what it might currently be. Unless it's reversible or you know the effect it will have, I'd probably wait until the custom mapping.
if your just "elongating" the hole, it wont make a huge difference.
if your cutting whole hood off then yeah wait. (also could catch a lot of water if you bike gets rained on). :?
Saki
Post by Saki »
k well i had a crack at it, just lengthened the hole and left the hood on! turned out a bit better!
thats what i did on my Z.
it looks like thats how it was supposed to be :)
Saki
Post by Saki »
Wattie wrote:thats what i did on my Z.
Yeah your prob right, i had a Laugh when i saw how small the intake hole is! i was thinking its maybe suitable for a smaller cc bike but dam it was tiny!
Chucked the BMC in and now the motor is heaps racier!
Did you have a pc3 in yours? i only have a downloaded map atm so i wanna go for more of a custom tune soon
nah i had stock pipes and stuff. i had a foam filter and the airbox opened. thats it. 8)
Saki
Post by Saki »
Wattie wrote:nah i had stock pipes and stuff. i had a foam filter and the airbox opened. thats it. 8)
oh i see, well i think its made a great improvement! very happy with my loud offensive Z :D
Daisy
Bike: GTR
Post by Daisy »
Was that your loud and offensive Z that went through Granton just before 9 last Sunday? With a small black package on the back?
Saki
Post by Saki »
Daisy wrote:Was that your loud and offensive Z that went through Granton just before 9 last Sunday? With a small black package on the back?
ummm, possibly, i wouldnt have had anything on the back tho. Mine is red but i cant remember if i was there or not last Sunday, i know i have been around that area around that date!
Daisy
Bike: GTR
Post by Daisy »
Heading to Symmons maybe? I was waiting at the Lyell Highway intersection for the crew going to Ross. 3 bikes went through and I thought the third one looked like yours. Sounded hawt - whoever it was. 8)
deafwish
Post by deafwish »
Hey Saki,
What map have you downloaded & where did you get it from?
Saki
Post by Saki »
deafwish wrote:Hey Saki,
Go here,http://www.powercommander.com
In hte middle of the page there is a few drop down menus for brand, make and year. Then it should have a list with all the setups.
I have aftermarket air filter, Yoshi TRS and PC3, there was a map i could download and install on the PC3 for that setup. Its good as a temp setup as i plan on getting a custom map!
If u need help, swing me a pm and i will help out!
