ZRX1100 Impeller oil leak ???
Postby devo » Fri Oct 31, 2008 8:19 pm
Hi all,
My recently purchased ZRX11 has an oil leak coming out of the little relief hole at the bottom of the Impeller shaft assy.
Is there a seal kit availalble for them or is it a replacement impeller assy jobby on this one. :D
Can't wait to ride it again :cry: 100kph means 100kph ;)
Thanks Guys
Devo
devo
Re: ZRX1100 Impeller oil leak ???
Postby FONC » Thu Nov 27, 2008 12:16 pm
G'day Devo,
What is exactly your description of an impeller shaft?? :oops: (water pump???? Silent shaft, Output shaft, gear selector shaft
Where is it and what does it do?
I know your bike is not a shaft drive so just wondering where it is on the bike/engine exactly!
Cie la Vie
FONC
Postby devo » Thu Nov 27, 2008 5:11 pm
The impellar shaft is the water pump assy , it contains a mechanical seal and an impellar.
devo
Postby FONC » Wed Dec 03, 2008 12:21 pm
Devo, there is one internal oil seal and two o rings you will only know the impeller shaft is u/s when you are looking at it! :)
Cie la Vie
FONC
