ZZR250 is & has been great, but idle (1300 +/- 100 rpm) changes from time to time being anywhere from 900rpm to over 3000rpm (!). It also has a flat spot just off idle and sometimes when you start to open the throttle from a cruising speed. It's not something that's bothered me much but I'm starting to notice it a little more and I'd rather fix it now than when it leaves me stuck on the side of the road in a few months time.
Not knowing a lot about carbies, the first thing I set about doing tonight was avoiding the job. After thoroughly degreasing the engine
Again, I don't know a lot about carbies so the second thing I did (after avoiding the job!) was to drain them. So I set the fuel tap to PRIME and hooked up a clear hose & bottle ($8 Repco brake bleeder kit FTW!). The right-hand carb didn't show up anything unexpected... it just drained out nice clean looking fuel with the occasional small air bubble.
When I repeated the process for the right-hand carb there was heaps of air, it looked like about a 60/40 mix of air and fuel coming down the hose.
Suggestions as to what the problem is?
Also, I assume the next thing to look at is balancing the carbs... apparently I need some vacuum gauge. I'm a bit scared because a mechanic once made a big deal about it... but is it really as simple as running the engine with two vac hoses hooked up to a gauge and turning the screw until it reads zero?
