just replaced clutch cable
Postby gazza2008au » Tue Sep 16, 2008 3:35 pm
hi guys and girls first post here and im looking for some help with my ZXR250C i just replaced my clutch cable with a A model cable cable it was about 3mm longer than the C model clutch cable now when i start the bike and put it into gear it stalls i have it adjusted correctly i can hold the clutch in with the bike in gear and start it soon as i even the slightest bit release the lever it stalls i think it could have something to do with the saftey feature in the clutchlever how can i fix this?
gazza2008au
Re: just replaced clutch cable
Postby timmyrocks » Tue Sep 16, 2008 4:09 pm
sounds like your clutch switch is playin games maby? make shore its connected properly (its up on the clutch lever),
if not from what i understand you put a A model cable on a C model????
if the switch is ok put the right cable on :P
Team Crash "09"
WR125 2004 Husqvarna :P
timmyrocks
Postby gazza2008au » Tue Sep 16, 2008 4:13 pm
i just put the old cable back on and still no good
gazza2008au
Postby gazza2008au » Tue Sep 16, 2008 4:24 pm
how bloody embarrasing :shock: no friggen wonder it keeped on dying i had the kick stand down now i feel like a real dick head! :oops: the kick stand was triggering the safey feature
gazza2008au
Postby timmyrocks » Tue Sep 16, 2008 4:25 pm
is your clutch switch connected ok?
Team Crash "09"
timmyrocks
Postby gazza2008au » Tue Sep 16, 2008 5:05 pm
nah the mechanic serviced my carby's and on the work form he wrote dodgy starter how i need to start it is hold my thumb on the start button and pull the clutch in untill the bike starts there something wrong with the clutch perch i think its called?
gazza2008au
