Nelso wrote:How much of a difference do braided lines make? Are the breaks more responsive, stop faster or just fade less? Do you need to change your pads as well or do the braided lines make enough of a difference by themselves? (these questions should probably be in the noob section)
I used dot 4 on mine?greaser07 wrote:just a question also,is is it better to use rbf 600 brake fluid when changing to ss lines or is dot 4 good enough?
Nelso wrote:Thanks guys. I have them on my 4wd but the lifted springs and big tyres make it impossible to notice how they feel. I just wasn't sure if they were meant to reduce fade or increase the ability to apply faster brake pressure, or both. Also, I was curious as to how noticeable the difference is on a bike and get an idea if it is worth the investment.
That's why I went with Superbike Supply and not purchased from o/s.Blurr wrote:Oh yeah FYI brake lines are legally meant to be ADR'ed.
ZXRobyn wrote:That's why I went with Superbike Supply and not purchased from o/s.Blurr wrote:Oh yeah FYI brake lines are legally meant to be ADR'ed.![]()
And in regard to fluid. . . . I believe Dot 5.1 would be a goer too.
