zx6r (f model) owners, Does this sound normal?
Postby IrishPete » Fri Jul 11, 2008 5:38 pm
Hi guys, quick question for you. I've got the bike running okay now, but there's a funny noise coming from the engine, on the exhaust header side.
To me, it sounds kinda valve-like, but I've not much experience with the kwaks so it could be normal..
I've taken a clip of it here: http://www.youtube.com/watch?v=emEfprnUMEM
Its the "ticka ticka ticka" noise that I'm on about. Is that normal or do I need to delve further?
IrishPete
Re: zx6r (f model) owners, Does this sound normal?
Postby timmyrocks » Fri Jul 11, 2008 5:42 pm
have you checked your valve clearances
also check if you have an exhaust leak
i couldnt really hear it on my laptop but thats where id start :)
cheers Tim
Team Crash "09"
WR125 2004 Husqvarna :P
timmyrocks
Postby IrishPete » Fri Jul 11, 2008 5:44 pm
Yeah, thats what I was thinking, will be re-checking the VC's tomorrow in case I messed up the first time :oops:
Don't think its the exhaust, as I can't feel any blowing when I put my hand near it.
IrishPete
Postby timmyrocks » Fri Jul 11, 2008 5:55 pm
fair enough if valve clearances are O.K you should be right i guess :)
do these have a cam chain?
Team Crash "09"
timmyrocks
Postby JetPilot » Fri Jul 11, 2008 6:15 pm
Mate that sounds to me like an exhaust leak.
Kawasaki Z1000r 2012
JetPilot
Postby Sulli » Fri Jul 11, 2008 8:23 pm
sounds to me like an exhaust leak. nice shot of the drive way :roll:
how about a shot of the muffler and the other connections
quick fix is silicon till you replace gaskets if thats where the leak is or just tighten the header bolts :?
Sulli
Postby IrishPete » Fri Jul 11, 2008 8:32 pm
Well I wasn't going for John Ford style video production quality man, as it was the sound I was looking for opinions on ;)
Thanks for the thoughts guys, will do a full check in the morning.
IrishPete
Postby Damon Z1000 » Fri Jul 11, 2008 10:43 pm
Exhaust leak, check the four into one collector box joint, header gaskets and bolt torque, just sounds like an exhaust leak but I may be wrong.
Team Crash 2010 Ooooops
Damon Z1000
Postby IsleofNinja » Fri Jul 11, 2008 10:44 pm
ref comment....
Yep as above I'm defo going for exhaust leak not valves.
Sounds like the header gaskets are stuffed or the header bolts loose or both.. Classic exhaust blow..(will pop and backfire on over run too huh???)
06 ZX10r , 95 ZX9r
07 FXST
IsleofNinja
Postby photomike666 » Sat Jul 12, 2008 1:14 pm
Stick something over the silencer exit (rag so don't get burnt), engine should stutter to stall. If it doesn't, there's an exhaust leak. It should also pressure the leak and you'll either hear or see where the gas is escaping.
Postby IrishPete » Sat Jul 12, 2008 5:01 pm
Congrats and thanks to all who suggested an ehaust leak, you were correct.
Was on headers 2&3, which have a connecting tube about 5inches down, looks like it got disconnected when I was trying to get the headers onto the flanges!
Re-connected & tested and its purring like a cat(all be it one thats been smoking 40 a day)
Now all I need is to make a seat and double check that everythings tightened and it's ready for the track!
IrishPete
Postby IsleofNinja » Sun Jul 13, 2008 12:17 am
Awesome -------- Enjoy mate
06 ZX10r , 95 ZX9r
07 FXST
IsleofNinja
