this is on my GPz750 air cooled donk.
so i'm wondering, anyone that has rebuilt and engine before or got it done. i need a parts list of as much as possible of whats required to bring a motor back to its past glory and last another 80-100 000km.
with my limited knowlege ive come up with a few parts, can you help with the rest? and whats an approx price of the majority of parts? 1500-2000?
pistons, pins and related parts (rings etc)
would my conrods be fine or should i just do them while everything else is being done?
full gasket set
camshaft / reground camshaft
valves, springs etc.
those half bearing sleeve things for the crank.
im not sure what all the bearings and seals are in the motor, but the bearings
clutch kit (mines fine, but why not while im there, its only 119 bucks)
starter motor gear (needs fixing anyways)
primary chain
gearbox bearings? (on this line, is there anything in the gearbox cheap/nececcary to replace...? the gears all feel fine with no whining.)
