race bike prep catch trays?????????
Postby timmyrocks » Mon Jan 28, 2008 11:47 am
ok guys rule 15.3.1.8 from MOMS says this:
With the exception of Period 1-5 Historic
machines, and production-based
machines without a lower fairing which
have ADR compliance, all machines,
including sidecars, must be fitted with
an integral lower fairing dam or separate
catch tray, which must be constructed to
trap and hold engine oil and / or coolant:
a) For 4-strokes machines, a capacity
of at least 3 litres,
b) For 2-stroke machines, a capacity of
at least 2.5 litres,
c) With no less than 2 holes, each of
25mm, which may only be opened in
wet race conditions.
how have u guys gotton past this one??
Team Crash "09"
WR125 2004 Husqvarna :P
timmyrocks
Re: race bike prep catch trays?????????
Postby robracer » Mon Jan 28, 2008 12:02 pm
You cant get past it you can either fabricate a catch tray or incorporate it as part of the fairing.
That or go naked!
Postby timmyrocks » Mon Jan 28, 2008 12:04 pm
lolz tempting 8) but i really like the side fairings there pretty hot n i spent alot of time with painting and stickers on it lolz so i would like to use them do u reckon some 1mm aluminum plate fabricated to sit in the belly pan would be acceptible???
Team Crash "09"
timmyrocks
Postby robracer » Mon Jan 28, 2008 12:12 pm
kawasaki250 wrote:lolz tempting 8) but i really like the side fairings there pretty hot n i spent alot of time with painting and stickers on it lolz so i would like to use them do u reckon some 1mm aluminum plate fabricated to sit in the belly pan would be acceptible???
As long as it covers the specs that would be fine & they are not that hard to whip up, we run one in the P5 SC even though we dont have to, we dont want to get blamed for oil on the track.
Postby timmyrocks » Mon Jan 28, 2008 12:31 pm
true true ahhh i am preparing this bike to race (obviously) lolz so far i have done
lockwired oil sump
oil filler
radiator drain
radiator filler
brake caliper bolts
brake banjo bolts
my oil catch tank is in my sealed airbox which i have fitted a drain to
i have a stock radiator overflow bottle so is there any need for an overflow from my overflow??
and do i need to have a fuel overflow? only place for it to do this is out of the breather so do i need to divert that to a small bottle of so me sort?
is there anything else u can think of?
thanks mate
Team Crash "09"
timmyrocks
Postby dave#3 » Mon Jan 28, 2008 12:41 pm
Is it possible to close up (glass over) any holes in the bellypan to make it hold the necessary volume of oil / coolant? Our trackys have an enclosed bellypan that holds this capacity (but no drains for wet weather). The alternative is a fabricated tray that fits under the sump as Rob suggested. I don't think going naked would be allowed, as your bike is a production based machine that wasn't ADRed with no lower fairing - I could be wrong but that's my interpretation of the rule.
http://www.oz4x4.net/gallery2
dave#3
Postby MadKaw » Mon Jan 28, 2008 12:44 pm
Its actually easier than that.. Get a baking tray from woolies and zip tie it into your belly pan..
Its been done many times before...
Postby timmyrocks » Mon Jan 28, 2008 12:47 pm
theres no holes in the belly only the join of the two sides and i would need to glass a rear so when i move it doesnt throw the crap out the back lolz so yer it probably would hold 3 litres i think? might give that a go it will be the light weight solution ay?? can u think of anything else i need for it to be able to race from lookin at my list above? cheers
Team Crash "09"
timmyrocks
Postby timmyrocks » Mon Jan 28, 2008 12:48 pm
MadKaw wrote:Its actually easier than that.. Get a baking tray from woolies and zip tie it into your belly pan..
haha u for real lolz and that gets accepted?
Team Crash "09"
timmyrocks
Postby robracer » Mon Jan 28, 2008 12:54 pm
:lol: bush mechanics Dave ;)
Postby dave#3 » Mon Jan 28, 2008 1:49 pm
kawasaki250 wrote:can u think of anything else i need for it to be able to race from lookin at my list above? cheers
I suspect you'll need engine protection covers too ... see http://ksrc-au.com/phpBB3/viewtopic.php?f=4&t=18601&hilit=
dave#3
Postby timmyrocks » Mon Jan 28, 2008 2:23 pm
15.2.3.4 Engine end case protectors mounted
using at least 2 of the original bolt
locations, and to protrude no more
than 20mm. This will relate to all 4
stroke machines
the more i read MOMS artice the more it gets stupid lolz so what stopping me from modifying the bolts so they have big heads protruding 20mm from the engine :) lolz its pretty vauge on details starting to consider canning the whole race thing n just doin track days on mah 250! lolz
Team Crash "09"
timmyrocks
Postby timmyrocks » Mon Jan 28, 2008 2:49 pm
those carbon fibre covers are useless might as well not have them they will not protect your engine case in a down side if im goin to do this i will do it right im goin to make spacers and get longer bolts and weld 10mm plate
oh its quite vague on details wats stoppng me on using liquid metal and building it up 20mm over my engine case
Team Crash "09"
timmyrocks
