oil light on
oil light on
Postby 98ninja » Thu Jan 24, 2008 12:54 pm
had a major service performed on the blade 2 weeks ago now.
everything was running fine
monday night i put a full erion exhaust system on disconnected the cable for the butterfly valve on the original exhaust.
other than that nothing has changed.
ride off to go home and 500m or so into the ride the oil light comes on.
so i stopped and checked the bike over and theres no signs of oil leakage. filter is still there sump plug still in the window shows theres plenty of oil in there. so i got back on and rode for another 500m and then the light comes on again.
rode home very cautiously with one finger on the clutch the whole way.
i have no freakin idea why the oil light comes on and stays on.
what could cause this?
i asked on an american fireblade forum and i get 15 " check your oil man!!!!!!"s back.
99 zx9r - back
98ninja
Re: oil light on
Postby Glen » Thu Jan 24, 2008 12:56 pm
Only thing I could suggest would be oil pump problems. I'd be getting it to a dealer pretty smartly
Re: oil light on
Postby 98ninja » Thu Jan 24, 2008 1:07 pm
my reasoning is the ride home was 30kms.
i really think the engine wouldnt go without oil for 30kms.
99 zx9r - back
98ninja
Re: oil light on
Postby Benno » Thu Jan 24, 2008 1:13 pm
You'd be surprised what engines can do.
At one of the Panel Beaters xmas parties I used to attend, they hooked up 2 holden engines with a can of fuel, pulled the carbs open and wired them that way, then used a battery to kick start em. They ran for a good 15 - 20 mins without any oil or water cooling, before they seized with the heat. Let them cool down for 15 mins, and they actually started again, and went for another 10!
Vespa!
Benno
Re: oil light on
Postby Neka79 » Thu Jan 24, 2008 1:45 pm
surely u have heard of what they did to zx6rs??
didnt they run em for like a day without oil.. and they didnt break down??
tho im sure it wouldnt be the healthiest motor..
Re: oil light on
Postby robracer » Thu Jan 24, 2008 1:49 pm
If there is oil in the sight glass then you can assume it has oil but the question is is the top end getting any....
The gauge is based off oil pressure not contents! ie no pressure no lube :shock: you will need to trace the problem starting from the oil sensor & see if the problem is electrical or if its mechanical like the oil pump... if in doubt & you cant work it out get to your LBS via trailer :?
Re: oil light on
Postby JetPilot » Thu Jan 24, 2008 3:35 pm
As Rob said, sounds to me like an oil pump problem. I would tow it to your mechanic and get it looked at asap.
Most engines will run for quite some time without oil before they go bang.
Kawasaki Z1000r 2012
JetPilot
Re: oil light on
Postby 98ninja » Fri Jan 25, 2008 8:34 am
its at kwaka newcastle right now
i also noticed the fuel injection light going off too
but its in good hands.
99 zx9r - back
98ninja
Re: oil light on
Postby Frank » Fri Jan 25, 2008 9:05 am
I had a similar thing happen to me on my ER5, turned out to be the sensor/sender unit was stuffed, but as Rob said it could also be a oil pump prob.
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
Frank
Re: oil light on
Postby bonester » Fri Jan 25, 2008 7:43 pm
Did you disconnect the oil switch when you fitted the exhaust? Might be your prob- the wire may be flopping around and occasionally shorting to the frame, turning the light on. :?
bonester
Re: oil light on
Postby photomike666 » Sun Jan 27, 2008 10:16 am
Nicely cut peice of black gaffa tape stick over instrument panel where the oil light is - hey presto, no oil light! :lol:
Re: oil light on
Postby Slow and wobbly » Sun Jan 27, 2008 10:28 am
What Kind of Honda?
By replacing the exhaust and disconnecting the exhaust valve the ECU can get a bit confused. Definitely unsure about Honda's but I know when the Yamaha exup valve is disconnected when fitting a full system there has to be some fuse pulling or wire chopping in order to get the computer to think its still there and functioning as it should. You mention the FI warning light comes on too? I'm guessing that by having the oil light come on Honda have basically created just a generic warning that something is no longer right.
The best way to rectify any problem with any Honda is to open the fuel cap, place a rag into the tank opening, set it alight and retreat to a safe viewing distance. Voila! No more problems! :D
Slow and wobbly
Re: oil light on
Postby jl4049 » Tue Jan 29, 2008 9:36 am
C1 ZX9R
jl4049
Re: oil light on
Postby 98ninja » Thu Jan 31, 2008 12:26 pm
59 dollars later
either completely remove the cables that are usually attached to the exhuast servo dealy
or come up with something to mount it on so the cable cant move around too much.
the oil is fine . the engine is fine etc.
now i have an on call weekend with work to celebrate
99 zx9r - back
98ninja
Re: oil light on
Postby robracer » Thu Jan 31, 2008 2:18 pm
98ninja wrote:59 dollars later
So you were charged $59 to be told to do that? :shock:
Next
Users browsing this forum: No registered users and 15 guests
