Sprockets....
Sprockets....
Postby MrStompy » Wed Jan 09, 2008 9:33 pm
Im replacing the sprockets on the R6 track bike.
(i know i should really be replacing the bike but sprockets are much cheaper ;) )
from what i can find on the net the standard size is 16 front 48 rear
currently this bike has on it a 13 front and 45 rear.
what effect should that have on acceleration and top speed?
most info i have read says to drop 1 in the front and go up 2 in the back. seems strange to me to go down at both ends.
any ideas why the previous owner would do this?
my head hurts when i try to figure it out myself :oops:
Currently it has good acceleration and any top speed reduction is not that noticeable by me (other than the speedo being incorrect)
MrStompy
Re: Sprockets....
Postby Neka79 » Wed Jan 09, 2008 10:17 pm
he went down 3 on the front.. thats the same as going up 8 or 9 on the back... hence why he went down 3 on the basck as well....
he probably wanted to go down 1 or 2 on the front, but couldnt get the sprocket or sumthing....
there is a gear program which tells ya ratio's and shit....
im guessing for racing, that would be good for acceleration, but u'd be losing top end... are u racing on tight small tracks?? or longer ones??
Re: Sprockets....
Postby IsleofNinja » Thu Jan 10, 2008 12:03 am
Try http://www.jtsprockets.com
Had good life out of them..Hardened carbon steel rather than usual crap though you may want an anodised alloy rear for a trackie.
site also has a very handy gearing chart when you look up the cogs 4 your bike. 8)
06 ZX10r , 95 ZX9r
07 FXST
IsleofNinja
Re: Sprockets....
Postby matt76 » Thu Jan 10, 2008 7:50 am
Maybe the prev owner went down on both to reduce the wheelbase as much as he could?
matt76
Re: Sprockets....
Postby MadKaw » Thu Jan 10, 2008 8:39 am
Wow, thats a big drop on the front...
I wouldn't go down any more than 1 tooth on the front as the tighter radius will draw HP and wear quicker..
For a 6 I would think 1 down on the front and a couple up on the rear would be fine...
Re: Sprockets....
Postby MrStompy » Thu Jan 10, 2008 11:39 am
im going to go back to a more standard sizing and then experiment from there.
1 down in the front and a standard rear for now.
we have a heap of spare rear sprockets so we can play around with them later. i wont be surprised if we never do though ;)
the previous owner was racing this bike in victoria and apparantly there is some short course tracks there where you dont get into the higher gears.
so maybe that is something to do with it.
thanks for the advice again.
MrStompy
Re: Sprockets....
Postby SnypR » Thu Jan 10, 2008 1:19 pm
MrStompy wrote:.............the previous owner was racing this bike in victoria and apparantly there is some short course tracks there where you dont get into the higher gears.
His last race must have been at Winton.
SnypR
Users browsing this forum: No registered users and 19 guests
