I went a tyre huntin this morning after letting the pollies know who I thought should be the person to show the world who we Aussies are!
After attempting to track down someone in Melbourne with a set of Racetech's or even Rennsports, I gave up and started to look for a deal on an alternative. After getting to know Laurie Genova at 1300Kawasaki in Ringwood, I had a set of Continental Sport Attacks fitted to see what they were like. Some of the dodgy UK Mag tests had rated them and sum of those "telligent Mericans" reckoned they were OK also.
It ended up being a bit of a drama in the end. I had them fitted up, paid for them and hopped on my bike to ride home. All felt pretty good as new tyres tend to do, with nice tip in with an unworn profile. Pretty soon I hit the freeway and cranked it up. I hit 112klms an hour and the front end started shaking. It was so bad the mirrors were flapping up and down as was the fairing stay and the faster I went, the worse it got with it eventually making the front wheel lift off the ground with the oscillation.
I u-Turned and went back. Initially I got the usually BS about it balancing perfectly, It must be a wheel bearing...no maybe the head bearings!!! Once the excuses were countered with logic one by one, he eventually agreed to remove the front wheel and have a look. So he put it on the balancer and to my eye (it was a bearing balancer not an electronic one) it was too heavy on the weights. He disagreed and reckoned it was perfectly balanced and that it was the tyre that had outer surface runout!!!
I also couldn't see the run out, but I wasn't going to argue any more and figured provided he balanced it properly this time it should be OK! He spent 30 mins making sure it balanaced up and I was off. I still can feel a little vibration, so I still maintain it is not the tyre. So Monday I am going to pull the wheels out and take them over to a mates place and balance them up on his properly!!!! I am sure they will be fine!
Now, what are they like? They are supposed to be the equivelent of a pilot Power/M3/015/Diablo etc., However I reckon they may be just a tad softer than M3's, and the like. I had them scrubbed in within a few turns and they warmed up pretty fast. I had the rear on it's edge by the third corner off the Yarra Blvd and the grip is good as is turn in and stability once on it's side. I ran up to the end of the blvd making sure it was A.clear of U NO Hoo! and B. the tyres were good and scrubbed and well warm! I U-Turned up the end and pinned it for a key in brain out red hot crack!
Feck I love ridin Muddaboiks like a fruitloop!!!
I really wanted to see how grippy these things were, so I started banging it on its side as hard as I could to try and break one of the ends loose and see what the reaction was like..........But fecked if I could get it walking around.
I'll have another crack up a road I know well tomorrow and let you know what they are really like!
Somehow I think the mileage might be limited. One run up and back of the Blvd had the edges balling up already! These might make a good cold weather tyre I think. Today was only 22 here in Melbourne, so It wasn't hot at all. I'll report back tomorrow.
