Pulling off snapped bolt
Postby javaman » Wed Oct 17, 2007 12:42 pm
Due to my interest with the new shiny torque wrench I have snapped a bolt :x
And the million-dollar question is: How to retrieve that broken part :cry:
-ariel circa 2007
http://GPZninja.blogspot.com/
javaman
Bike: GPz900
Re: Pulling off snapped bolt
Postby Ratmick » Wed Oct 17, 2007 12:49 pm
Well it depends on what type of bolt, where it is and how much is above the surface...
Normally you would drill a hole down the middle of the stump of the bolt and use an Easy-out...unless it's high-tensile where you may have trouble with the drill OR it's sheared at an angle (ditto). Best case scenario is that you'll get the remainder out without a damaged thread, worst case you'll need to drill and install a Helicoil and a conversely larger bolt...or buy a new part.
Good article on the usage of an Easy-out: http://crustyquinns.com/tech/easyout.html
Mick
Ratmick
Team Hornet
Postby Smitty » Wed Oct 17, 2007 12:51 pm
Ratmick wrote:Well it depends on what type of bolt, where it is and how much is above the surface...
Mick
absolutely as Mick sez...........
and besides, how did you snap a bolt if using a Torque wrench...? :roll:
Postby javaman » Wed Oct 17, 2007 12:56 pm
Did I say 'new' :lol: ... I had no experience using and adjusting it. Now I reckon the ol' elbow still best for the job :(
Thanks I'll go to supercheap and see if they have those extractor thing.
-ariel circa 2007
javaman
Bike: GPz900
Postby Strika » Wed Oct 17, 2007 2:28 pm
Ring me if you have no luck Andi, I have an easy out set in the tool box mate. :)
Postby Neka79 » Wed Oct 17, 2007 2:49 pm
or give Stace a call... he knows all about bolts!!
Postby Smitty » Wed Oct 17, 2007 3:09 pm
Neka79 wrote:or give Stace a call... he knows all about bolts!!
ROFLMAO and
....ROFPML...... :lol:
Postby mike-s » Wed Oct 17, 2007 11:06 pm
Easyouts..... supacheap have them for about fifteen bucks or so. Ive now got two sets, the one i bought from supacheap, and a $50 set from bunnings that was some uber nifty brand or some shit. Bought the supacheap ones because for the extra $4 over the basic set you get the little clamp doodad that you can use to grip the easyout to thread it in smoothly
Postby goanna_38 » Fri Oct 19, 2007 12:23 am
Never been keen on easyouts. Seen a few snapped off through exuberance or just bad luck. You snap off one of those babies and you have fallen out of a small can of worms straight into a 44 gallon drum full of worms.
If a man says something, and there is no woman there to hear him, is he still wrong?
goanna_38
Bike: ZZR1100
Postby mike-s » Fri Oct 19, 2007 8:17 am
thats why you use a shitload of penetrene to soak it first, in case it was rust on an undo attempt that sheared the head. But in this case it was just exuberence that caused the bolt head to shear off, i'd be reasonably confident that as long as the shear was pretty flat and that the drillhole is as small as you can put in there (smaller = better as you dont require as much depth, which if your off centre could mean your drilling into the surrounding metal, not dead straight through the bolt) you should be relatively ok.
Postby MiG » Mon Oct 22, 2007 2:42 pm
65% Nitric acid diluted 1:1 or weaker :) But it's slow and labour intensive. I'm assuming it's snapped within an aluminium part, otherwise you don't want to use nitric acid.
One of the studs on the TZR is seized so solidly that when I welded a nut on the stud just snapped.
MiG
Users browsing this forum: No registered users and 24 guests
