how to fit oggys/frame sliders
Postby MrStompy » Thu May 24, 2007 10:56 pm
Im assuming that when you fit frame sliders or crash knobs they bolt through that top engine mount.
is that correct?
if so how do you remove the engine bolts?
was just looking at mine and those bolts look kinda weird - i couldnt see it being all that straight forward - although others tell me its a simple job.
MrStompy
Postby Smitty » Fri May 25, 2007 9:01 am
ummm..depends
on the model
most are different
on the 12 there are 2 spots
near the swing arm pivot
or
on the frame support on the engine
I just undid the existing bolt (using a hex key)
and bolted up the slider......
hth
Postby MrStompy » Fri May 25, 2007 9:43 am
THanks smiity
that does help.
i wasnt sure if was meant to undo that hex bolt and replace it or what.
i guess i was just a little concerned about pulling out the engine mount bolts and replacing them with an unknown quantity. atleast with the standard bolts you know thats whats in all the other bikes too.
but i guess these people know what they are doing.
MrStompy
Postby red_dave » Fri May 25, 2007 10:05 am
You can have a look at how mine are mounted on the weekend man...
Postby MrStompy » Fri May 25, 2007 10:31 am
thanks dave - that would be real handy actually.
MrStompy
Postby Stereo » Fri May 25, 2007 11:20 am
I thought they came with instructions.
Postby mfzx6r » Fri May 25, 2007 11:30 am
They all mount different.
Some replace and mount on a engine bolt some mount to the heavier fairing bolts and some come with plates that you bolt across 2 bolts and then bolt the crash to that, these are usualy the ones that you dont have to cut a hole in the fairings to mount the oggies .
As Stereo said read the instructions and hopefully you cant go wrong.
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r
Postby Neka79 » Fri May 25, 2007 1:20 pm
yea..mario is right (for a change)..u can buy sum that u cut in to the fairing, and sum that u dont, it depends on the bike, the crash's and that, and they should have instructions too..
and considering they should be tested , the bolts they supply u should be up to standard..
Postby dave#3 » Fri May 25, 2007 9:24 pm
Hey Jayc, if you're not real confident you're welcome to do this at our place - I've got a good compliment of tools and I've done this once or twice before 8)
http://www.oz4x4.net/gallery2
dave#3
Postby Wattie » Sat May 26, 2007 3:00 pm
just zip tie them to the mirrors Dude... :lol:
they'll hit the ground 1st, might save something :lol:
Users browsing this forum: No registered users and 28 guests
