Paint off engine
Paint off engine
Postby MickLC » Tue May 01, 2007 11:35 am
As I've been cleaning up the old Z, one of the things that has really been bugging me is the patchy paint on the fins on engine. There are also some bits on other parts of the engine that seem to flake off pretty easily, so I shouldn't have any trouble getting them off, but the really tricky bits are on the fins on the outside of cylinders (see below).
Any suggestions for effective ways to remove the paint that don't require me to take the engine apart and won't cause any other damage?
Postby mfzx6r » Tue May 01, 2007 1:06 pm
maybe some type of hand wire brush
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r
Postby photomike666 » Tue May 01, 2007 1:25 pm
If you have a compressor, get a sandblasting kit and use plastic beads. Using sand will destroy the alloy, but plastic will work wonders (it's one of the agreed ways of stripping paint from an alloy gas cylinder to prep it for ultrasound inspection). I believe many merchants who carry sand/shot for blasting will also carry plastic beads.
Postby MickLC » Tue May 01, 2007 1:37 pm
So how much of a mess will the beads make? Will they get into everything on the bike so I have to spend ages cleaning them out?
Postby photomike666 » Tue May 01, 2007 1:45 pm
that would be the case; a portable vacuum would be the best idea. Preperation may be the key. Use rags to cover anything you don't want the beads in/to remove the surface from. Oh, and start low perssure.
Postby plane » Tue May 01, 2007 5:09 pm
Mick C wrote:So how much of a mess will the beads make? Will they get into everything on the bike so I have to spend ages cleaning them out?
Spend ages masking it up first. As photomike said, "prevention is the key"
Pete
Live Fast, Die Sideways
plane
Postby Gosling1 » Tue May 01, 2007 10:32 pm
Mick - when I removed all the paint from the Pearl's motor a few years ago, I just used normal paint-stripper - that thick gel stuff. Apply with a 1" paintbrush, you can get right into the fins with one of these.
It worked great. It will peel old engine paint off the block easily. To remove it, I just pushed the bike outside, and used one of those garden-sprayers full of water, set to 'Stream', and basically hosed it off in small sections. Tape up the frame tubes so none of the stripper gets on the frame.
It takes a bit longer than using your garden hose, but if you use that on high-pressure, you will spray paint-stripper all over the place :shock: - the hand-sprayer is much better...
And you can just apply a bit more here and there for those 'stubborn' spots that didn't come off the first time......
Postby Rossi » Tue May 01, 2007 10:56 pm
Just scratch off the flaky bits with a screwdriver and apply Black engine paint liberally :wink:
Then IF you ride it fast no one sees :lol:
Rossi
Postby MickLC » Tue May 01, 2007 11:25 pm
Gosling1 wrote:Mick - when I removed all the paint from the Pearl's motor a few years ago, I just used normal paint-stripper - that thick gel stuff. Apply with a 1" paintbrush, you can get right into the fins with one of these.
Cool, I'll give that a go then if I know it's gonna work OK 8)
Postby MickLC » Tue May 01, 2007 11:26 pm
Rossi wrote:Just scratch off the flaky bits with a screwdriver and apply Black engine paint liberally :wink:
hahaha the problem is I want to leave the metal bare...so no coverups of screwdriver scratches :lol: :lol: :lol:
......and I don't know how fast it's gonna be yet :wink:
Postby Gosling1 » Tue May 01, 2007 11:29 pm
One trick with applying the stripper - brush it on thick, and only brush it once. (ie, don't brush it back and forth) ......then, let it 'settle' into the paint and soften right up before you spray it off..........that old engine enamel can be baked on pretty hard.....
wear rubber gloves and a long-sleeved shirt - the shit is toxic and will burn on exposed skin, if it gets on your skin wash off *immediately*. *DO NOT* get it into your eyes under any circumstances......clear safety goggles are *highly recommended*
Can you tell I am doing my Cert IV in OH&S at the moment ?? :lol: :lol: :lol:
Postby hoffy » Tue May 01, 2007 11:30 pm
You may want to make sure it starts before you strip it and rebuild the bike :lol:
Postby Neka79 » Tue May 01, 2007 11:51 pm
lather a hot vindaloo on it...that may strip the paint...
Postby hoffy » Wed May 02, 2007 10:53 pm
well it has stripped the paint of the bathroom walls :shock: :lol:
Postby Duane » Thu May 03, 2007 8:19 am
I heard a rumour Hoffy's toilet is held together by 100 mile an our tape after the vindaloo ate through the ceramics
www.bromancer.com.au
Duane
Next
Users browsing this forum: No registered users and 22 guests
