Tyre plugs (puncture repair type)whats the go??
Postby Burky » Thu Mar 29, 2007 9:12 pm
Looking at the bike tonight and nitices there is a plug in the rear :evil: I thought it was a bit of road crap but it ain't. The tyre still has plenty of tread (almost new), but don;t know if it should be replaced :evil: .
Pilot power,by the way!!!
Arn't they puncture prone :wink:
Some advice would be good?
Burky
Postby mick_dundee » Thu Mar 29, 2007 9:54 pm
"Plenty" of people ride the tire to it's death with a plug in em Burky, havind said that there is a "theoretical" speed limit you're not supposed to go over with em in, think it's 80kph but heard many a person ignore that too, your call I guess. Dunno i'd be replacing it if it didn't need replacing though.
Postby Loz » Fri Mar 30, 2007 12:19 am
I've done over 200 on a plugged tyre, didn't know I shouldn't be. If you're worried about it - enough for it to affect your trust in the tyre - then bugger it off.
Nekkid Niner.
Loz
Postby Burky » Fri Mar 30, 2007 7:45 am
Riding with it at the moment is unnoticabe. Just was unsure wether they were a temp. fix or they let go after a while.
Burky
Postby ty » Fri Mar 30, 2007 8:16 am
I've done >1000kms on a recently plugged tyre at freeway speeds.
That's plugged from the inside - not the roadside plug things.
For the road I think the internal plugs are safe enough - wouldn't go to the track though.
Not sure how the roadside plugs hold up - I'd personally treat them as temporary I think and get it plugged properly or replace the tyre.
ty
ty
Bike: Honda
Postby Glen » Fri Mar 30, 2007 8:33 am
They're pretty cool mate. Hoffy was running around on an old one of mine with a plug in it for ages. I put a temporary in it and he had it plugged from the inside
Postby MadKaw » Fri Mar 30, 2007 8:52 am
Firstly, take it back and try it on for a new one... (you did get it from a dealer didn't you.?)
Secondly, if that falls thru, and it probly will, don't worry about it if its been done correctly. Make sure its the mushroom one plugged from the inside. I had one of those in a nearly new tyre and ran it too its death, including a couple of track days, with no problem.
Ask Damon about the rear tyre on the 9 he bought from Parra Kawi. Not only did it have 2 plugs in it, it also had a tube. We found that out when the tube got a leak..
Users browsing this forum: No registered users and 28 guests
