Throttle quickeners
Throttle quickeners
Postby deafwish » Wed Mar 28, 2007 9:30 pm
Hi all,
I'm looking for ideas on how to quicken the throttle on my Z thou.
I rarely hit full throttle, simply due to it being too bloody hard to twist that far around..... :x
Any ideas?
deafwish
Postby shrike » Wed Mar 28, 2007 9:42 pm
Do you mean a quarter turn throttle?
That'll help you out!
Here's a link to yoyodyne's site.
Just what you're after but I think a little expensive:
http://www.yoyodyneti.com/ProductInfo.a ... tid=E80061
shrike
Postby Neka79 » Wed Mar 28, 2007 10:52 pm
umm im sure madkaw would know where to get these..i reckon hes had a few on race bikes...
Re: Throttle quickeners
Postby Loz » Wed Mar 28, 2007 11:19 pm
deafwish wrote:I rarely hit full throttle, simply due to it being too bloody hard to twist that far around..... :x
Any ideas?
It seems we need some forearm exercises to address the limpness in your wrists there Daz... :P
Seriously, you know in advance when you want to reef it right on, so just roll your wrist over, take a forward grip and give it the berries! A quick action throttle is a waste of time on a roadbike; normal road use rarely sees the throttle opened more than 30%, even on fast takeoffs, wheelies and overtakes. You really want to sacrifice fine control just so you can have a once-or-twice-daily full throttle kick without having to reach for it?
Loz
Postby Stretchy » Wed Mar 28, 2007 11:21 pm
http://www.doublezracing.com - This is a cheap alternative, $25 worldwide posted. It is just an insert you put over stock throttle tube and then adjust cables. I have one on my racebike, its quicker than stock but i want something even faster for next time.
http://www.gptechllc.com/productsthrottles.htm - More expensive but has 4 different throttle speed options. Would love to try one of these myself.
O5 ZX10R Superduperbike
ZX7R
Stay on the gas...maybe you'll save it, maybe you won't, but at least it will end the suspense....
"If everything seems like its under control, you are not going fast enough." - Mario Andretti
Stretchy
Postby matt76 » Thu Mar 29, 2007 5:36 am
Daz, i made my own. It was a piece of cake. A bit of an irrigation fitting and a tube of superglue is all you will need. I love mine. It only reduced the travel by about 6 or 7mm but was enough to eliminate the problem as you say. I found on track days it just had too much travel and i had to really concentrate to make sure my hand was in the right position.
See here:
http://brisbanebikers.com/phpBB/viewtopic.php?t=3249
Matt
matt76
Postby petro » Thu Mar 29, 2007 8:18 am
I got one from riderforums, but is the same a Matts, just a bit thicker and it gives about one 5th of a throttle turn instead of 1\4, and it is great, you just need to cut some of the cable guide out at each end to stop it from binding.
[IMG]http://i50.tinypic.com/2cohlwg.jpg[/IMG]
petro
Postby MadKaw » Thu Mar 29, 2007 9:05 am
I've got the double z racing one in my 10.. Its about the cheapest option you'll find, unless you make your own (and it doesn't look that difficult.)
Its not as quick action as a race throttle but a good option for the road / track.
Not sure if he makes one for the z.
Advantage is it uses all the std parts..
The quick action throttle that was on my zxr ran thru a nylon bush and with the flat slides was hard to twist so I bought one of these on ebay (UK) with a roller bearing.
http://www.spys.co.uk/revlimiter_racing17.htm
Not too pretty and looked a bit cheap (cost about $40) so I wasn't too sure, but I'm pretty happy with it so far..
Now, on the zx9r, I had a domino quick action.. Very short thro and it was great, a bit more expensive though... I'd get one of these again...
Postby petro » Thu Mar 29, 2007 12:40 pm
Here's a link to where I got mine, cost about $ 25 all up.
http://www.motospecialties.com/store.as ... 0Throttles
Here's a link about installing it.
http://www.riderforums.com/showthread.p ... +quickener
petro
Postby photomike666 » Thu Mar 29, 2007 1:56 pm
MadKaw wrote:I've got the double z racing one in my 10.. Its about the cheapest option you'll find, unless you make your own (and it doesn't look that difficult.)
I just checked into these guys. A company called Trialzone imports these and has a distributor in most states. The Vic distributer is JJ Marine in Port Melb, and I'm off to see them Monday. Price is a reasonable $39 and comes as a replacement throttle assy.
Postby deafwish » Thu Mar 29, 2007 6:12 pm
petro wrote:Here's a link to where I got mine, cost about $ 25 all up.
Thanks Petro.
I've searched round and this one seems to be the best around.....
I'm about to order mine and if anyone else wants one, we can save a little on shipping. Will be about $28 each - ish.....
PM me, ASAP! Will order on Friday evening......
Daz.
deafwish
Postby MadKaw » Thu Mar 29, 2007 7:30 pm
Be careful you get the right one... the trials ones aren't always suitable for road bikes...
http://www.yomoto.co.uk/2.html
Postby photomike666 » Fri Mar 30, 2007 9:14 am
Cheers Dave, I might take my assy along to make sure it fits.
Users browsing this forum: Google [Bot] and 15 guests
