Brake caliper bleed nipples -SOLVED
Postby MrStompy » Mon Mar 19, 2007 6:53 pm
hi
Im after some aftermarket bleed nipples for my brakes.
I want the one way jobs that make it real easy to bleed the brakes.
I was going to order the HEL ones but there is apparantly a delay for the bleed nipples and they may take a reasonably long time to arrive - according to a guy i spoke to from AUStreetfighter (nipples only, the other stuff they sell is fine).
So what are you using? where did you get em from and what did you pay?
Thanks again for your advice.
MrStompy
Postby MrStompy » Mon Mar 19, 2007 7:20 pm
Found some on ebay...
i swear when i looked this arvo there wasnt any there (for a decent price)
then i do another search now and find some cheap as :roll:
oh well - thats ebay i guess
thanks anyway.
MrStompy
Postby robracer » Mon Mar 19, 2007 7:31 pm
Standard ones bleed fine just gotta be patient & helps to have a spare pair of hands... have tried the fancy ones but dont like the non back flow to tell if you have cracked the nipple enough :lol: :lol:
Good luck with it Stompy!... PS seen the Zed lately have a look in this topic
a few lines down
Postby MrStompy » Mon Mar 19, 2007 8:16 pm
robracer wrote:Standard ones bleed fine just gotta be patient & helps to have a spare pair of hands... have tried the fancy ones but dont like the non back flow to tell if you have cracked the nipple enough :lol: :lol:
a few lines down
Thanks Rob.
Yep ive been keeping a close eye on your mods to the Zed.
its bloody fantastic what youve done to it.
MrStompy
Postby Johnnie5 » Mon Mar 19, 2007 9:44 pm
go to kmart etc and buy the one man bleed kit , $10-$15 , hose with a 1 way valve in it ,
fit hose, crack nipple and pump away
Johnnie5
Postby swabio-ACT » Mon Mar 19, 2007 10:33 pm
Johnnie5 wrote:go to kmart etc and buy the one man bleed kit , $10-$15 , hose with a 1 way valve in it ,
mate... i am sure they are only about $4 from autopro/supercheap etc..... (could be wrong though ;) ) the thing with them is they work great.... but make sure you clean them out! Or the valve gets stuck..... (hey gos)
I was having some probs bleeding my brakes and gos came over to help..... and no matter how much pumping etc.... nothing was working.... and then BAMMMMMM of shot the whole valve assembly.... and fluid was all over the shop! after that resorted to the two man job with Gos's help!
Drove me nuts... oh and wasted about 1/2 a bottle of RBF600 ! Although quite amusing when the valve let go! Was quite loud and violent....(kinda like gos after a decent curry! )
swabio-ACT
Postby Stretchy » Mon Mar 19, 2007 11:37 pm
Those work if everything is cold, I kept burning the hoses when i was at the track.
Stretchy
Postby Gosling1 » Tue Mar 20, 2007 6:03 pm
swabio-ACT wrote:.... but make sure you clean them out! Or the valve gets stuck..... (hey gos)
:lol: not as bad as after 10 bourbons :twisted:
Yeh, clean out those one-way nipples, or they become no-way nipples, and its *splat* over everthing when they let go.... :?
Postby MrStompy » Wed Mar 21, 2007 11:40 am
sounds like you guys had a good time installing these things.... :)
thanks everyone for the tips.
i ordered some off ebay for about $4 each.
i will hang onto the old ones though incase i run into to probs like swabio/Gos mentioned.
My bike is going to be a braking monster pretty soon.
going to install a set of EBC HH pads (thanks for the tip swabs) as well as new brake lines and fluid.
just waiting for the parts to arrive.....
MrStompy
Postby swabio-ACT » Thu Mar 22, 2007 1:13 am
MrStompy wrote:sounds like you guys had a good time installing these things.... :)
Just remember that the aftermarket pads are harder on the discs (apparently) so may pay to keep an eye out on ebay for some cheap spares ;)
swabio-ACT
Users browsing this forum: No registered users and 22 guests
