Radiator fan
Radiator fan
Postby ozten » Thu Mar 15, 2007 4:07 pm
I just come back from a ride and once i stopped the temp was 110.
However the fans still hadnt kicked in does anyone know wen there suppost to i thought they would have by then. Its an 06 636
ozten
Postby J.B » Thu Mar 15, 2007 4:17 pm
dont know how much has changed since but the fan on my '03 kicks in at 100 and doesn't stop till it goes back below ~95.
J.B
Postby ozten » Thu Mar 15, 2007 5:39 pm
do both your fans kick in or just one
ozten
Postby J.B » Thu Mar 15, 2007 5:48 pm
only got one, so no help here. In my manual it say fan will switch on between 92-104 and will switch back off after the temp has fallen by 3-8 degrees.
If you got a manual it should say in there.
J.B
Postby FrogZ » Thu Mar 15, 2007 7:12 pm
The temp will rise once you stop as there is no cooling air going through the rad. Its not unusual to see the temp jump ONCE you stop.
Chances are it was actually BELOW the kick in point when it was going.
DEFINITELY keep an eye on it but. :wink:
FrogZ
Postby J.B » Thu Mar 15, 2007 8:25 pm
ok ozten, just got an 05-06 636 manual and it says the thermo (apparently there's only 1) should kick in at 95 and stop once it goes back below 90degC, mind you this is an american manual but shouldn't be hugely different, but someone might be able to clear that up.
J.B
Postby ozten » Thu Mar 15, 2007 9:09 pm
i just found out that it has been running but doenst run with your ignition on which i thought it did, which is stupid cause the temp rises the most wen you turn it off cause of heat soak. My bad too it does only have one fan.
ozten
Postby ozten » Thu Mar 15, 2007 9:12 pm
This all come about cause i got stock in the m5 tunnel today in a traffic jam even though i was lane splitting my temp still hit 110, i was shitting myself cause i didnt wanna stop in there to let my bike cool down. Holy shit it is not cool riding in that tunnel in traffic :shock:
ozten
Users browsing this forum: No registered users and 19 guests
