Problem is once I got to work this morning, the REAR brake went completely!! I don't use the rear much, just around the car park, but it sank right to the bottom!
If unsure how to do this just check with Marty A.K.A. Strika. He has to do it with his penis, Old war injury apparentlyStrika wrote:Did you pump the rear brake lever back up after fitting the pads? Sounds like not!
FrogZ wrote:Apply the brakes lightly to bed in (should already be done by the sound of it) any high points will be taken off, there should be NO drag. If there is they are "pumped up" and need to be released through the bleeder.
IMHO.
As for the back one, if they have "gone to the bottom" of the travel there is obv. something wrong. Check all connections and rebleed. If it still does it you obv have a leak somewhere and if it is not connectors then it is a seal, check for fluid leaks, you should be able to smell and see it.
If not it is a master or slave leak.
have fun (NOT)
FrogZ wrote:There is a slight chance if you leave them rubbing they will glaze up too (get all shiney and not work)
If so take to them with some sandpaper.
mike-s wrote:i'd say 200-250, you only need to take a fraction of a mm or so off.
oh and r.e. the sticking, even though its a reasonably new bike, the seals on the brakes could be shot. they might not leak, but they may not be letting the pistons retract enough after you use them. Another sign of this is if you get uneven wear on each pad, like one piston is pushing more than the other.
Aussie Ninja wrote:Don't know if this will help but the pistons in the tokicos can get stuck out sometimes, as in when you release the lever the pistons don't move back at all and that side ramains in contact with the disc. Happened to me. Outer pad ok, inner pad not there.When I changed the pads hit the caliper with some cleaner, all sorted.
ross79 wrote:Aussie Ninja wrote:Don't know if this will help but the pistons in the tokicos can get stuck out sometimes, as in when you release the lever the pistons don't move back at all and that side ramains in contact with the disc. Happened to me. Outer pad ok, inner pad not there.When I changed the pads hit the caliper with some cleaner, all sorted.
Thanks, will add CRC to my list. Hopefully will have it sorted tonight.
Users browsing this forum: No registered users and 24 guests
