1. fender hugger respray, 2. Chain tension-gear
Postby BikerBoy » Thu Feb 01, 2007 12:43 pm
1. Is removing the front tire hugger (the plastic bit over your front tire) easy? is it just a matter of removing the 2 bolts either side and pull it off? (wanting to have it resprayed) or do you have to remove the whole tire to take the plastic hugger off?
Side bar..
2. Does having a chain with too much give in it make gearing up and down messy, clunky and noisy? or has the chain tension nothing to do with the gear mechanism (currently i have about 2.5inch of movement in the chain)
BikerBoy
Re: 1. fender hugger respray, 2. Chain tension-gear
Postby J.B » Thu Feb 01, 2007 2:57 pm
BikerBoy wrote:currently i have about 2.5inch of movement in the chain
:shock: thats a fair bit mate should only be about ~1 inch of slack, maybe a little more. Wont necessarily make shifting noisy but will be noisy fullstop.
J.B
Postby hidepenny » Thu Feb 01, 2007 2:59 pm
wow someone is asking the same level of difficulty questions as me, have u checked out my other collection? NEKA loved them!!!
anyway back on the topic!
just the bolts and the clips of ur front brake lines.
hidepenny
Postby mrmina » Thu Feb 01, 2007 5:01 pm
the front fender is easy to take off, u dont need the wheel off to take it off.
the slack on the chain should be about 30mm.
Postby BikerBoy » Mon Feb 05, 2007 1:21 pm
I tried removing my front fender on the weekend, there are 4 bolts, the first 2 were easy to take off, but the two behind seem impossible to get too, can't get a spanner or even my hand past the wheel to get to them.....
blows...
If you get a chance have a look at your front fender, there has to e some specific spanner or tool to be using..
BikerBoy
Postby mike-s » Mon Feb 05, 2007 1:45 pm
mine had an insanely tight fit and took lots of fugging around to remove it. but presumably it can be done.
Postby robracer » Mon Feb 05, 2007 7:20 pm
BikerBoy wrote:I tried removing my front fender on the weekend, there are 4 bolts, the first 2 were easy to take off, but the two behind seem impossible to get too, can't get a spanner or even my hand past the wheel to get to them.....
blows...
mmm....... remove the front wheel?
Users browsing this forum: No registered users and 21 guests
