[quote="photomike666"]Did mech use copper grease on back of pads? This normally gets rid of squeal, but may be it?
quote]
That's pretty funny Mike!!!!!
Just for those that would like to know, Copper grease on the backing plate won't stop your discs from making noise! The noise is a result of friction between the rotor and the pads. Copper grease at the backing pad has no effect on this. In reality, the more noise they are making, the better they are working. Have you heard the noise that race car brakes make??? They make this noise partially due to the materials they use, as they don't have to worry about anything but stopping power and resistance to fade. They aren't particularly worried if the brakes make noise, just as long as they stop, and stop well! The stuff we get to use in our cars and on our bikes has been designed to be a happy medium. They work from cold, work when relatively hot, work in the rain and the dry and they are relatively quiet for ADR and comfort purposes. If we were to truly get race spec brakes, they would make loud horrible noises, and wear out both the rotor and the pads very quickly!
I have a mate who works for one of the brake companies as an engineer, and his head is full of all this type of useless information!
All I can say about the noise in your brakes, is "Harden the fuck up!"
