Electrical wiring ???
Postby Burky » Fri Oct 27, 2006 2:04 pm
I currently have a portable GPS , the question is putting a ciggy lighter under the rear seat for power to use it on the bike? do i wire this directly to the battery or elsewhere. i don't want to blow anything up both are bloody expensive(bike elect and GPS) :shock: .
I was going to do a direct hook-up to the battery but figured i would ask first :?
I know some of you have done it before. :?: :?: :?:
Burky
Postby BladeBoy » Fri Oct 27, 2006 2:07 pm
I would find a connection that was powered with the ignition was on, but thats just me :wink:
BladeBoy
Postby Stereo » Fri Oct 27, 2006 2:12 pm
Javaman has one on his bike Im pretty sure, PM him...
Postby Burky » Fri Oct 27, 2006 2:37 pm
Thanks Stereo will do.
Burky
Postby Rossi » Fri Oct 27, 2006 2:54 pm
Just make sure to use an in line fuse holder :wink:
Rossi
Postby Smitty » Fri Oct 27, 2006 2:54 pm
BladeBoy wrote:I would find a connection that was powered with the ignition was on, but thats just me :wink:
yep...and one that is fused..... :wink:
Postby BladeBoy » Fri Oct 27, 2006 2:55 pm
Thank's no problem at all :wink:
BladeBoy
Postby BladeBoy » Fri Oct 27, 2006 2:56 pm
I was guessing that the GPS had a fuse :roll:
BladeBoy
Postby Burky » Fri Oct 27, 2006 3:32 pm
I think i does but will use another just in-case $2 fuse is cheaper than a $600 GPS :oops:
Burky
Postby mike-s » Fri Oct 27, 2006 7:23 pm
Rossi wrote:Just make sure to use an in line fuse holder
absolutely
bladeboy wrote: I was guessing that the GPS had a fuse
shit no, at the best you'd be looking at a fuse built into the gps->ciggie lighter adapter, but i'd also be putting an inline fuse in there and just a 1amp fuse, max, even a 500mA fuse would be enough.
Postby RG » Fri Oct 27, 2006 11:34 pm
How much current/power will you be drawing?
RG
Postby mrmina » Sat Oct 28, 2006 12:15 pm
RG wrote:How much current/power will you be drawing?
fark, u can tell th engineer is asking the questions. :lol:
Postby mrmina » Sat Oct 28, 2006 12:19 pm
i agree with all the above.
1. use an ignition powered point
2. use a fuse
3. determing a current draw by the gps and use appropriate fuse.
you can use a direct line from the battery. In that instance, u have to use a fuse due to spikes in voltage/current from starter, alternator, engine etc.
Postby Burky » Sat Oct 28, 2006 12:22 pm
All wired up :wink: . It sits nicely beside the gauge cluster, just enough clearance :shock: . I did use an inline fuse and the charger for the GPS has a fuse also. Once the camera is working i will post a pic, i even got a no smoking plug! :lol: not for any other reason just incase water happens to get near the lighter :shock:
Burky
Postby BladeBoy » Sat Oct 28, 2006 3:12 pm
Cool, a job well done :supz:
BladeBoy
Next
Users browsing this forum: No registered users and 15 guests
