changing tyre profile?
Postby MrStompy » Wed Oct 25, 2006 9:36 am
will changing the front tyre from a 120/65/17 to a 120/60/17 have a noticeable effect on the bikes handling?
from what i have read i think Kawasaki used the 65 on the front rather than a more common 70 as it helps it tip in better. (is that correct?)
would a punter like myself notice this difference anyway?
Im going in for a new set of tyres this weekend and the guy mentioned going down to a 60 (he had to look twice for a 65). i will stay with the standard profiles for now but was just curious.
Im going with the pilot powers since i have heard so much positive stuff about them.... $450 a set fitted. cheapest tyres in sydney http://www.spmotorcycles.com.au/
MrStompy
Postby Strika » Wed Oct 25, 2006 10:46 am
As a personal preference, I would be more inclined to suggest a 70 profile for the 636. I find 60 and 65 profile front tyres to be unforgivining at full lean. That just slightler higher sidewall, enables a little give, rather than just letting go at full lean. Bump absorbtion is also better, and surprisingly enough, that is the preferred option still in Supersport racing! :)
I find 60 and 65 series tyres to skip and dance around on small surface irregularities. the 70 profile settled the front of the 636 to the point where I never bothered with a damper for it! :wink:
Postby I-K » Wed Oct 25, 2006 1:19 pm
Strika wrote:As a personal preference, I would be more inclined to suggest a 70 profile for the 636.
*points up*
What he said...
I-K
Postby MrStompy » Wed Oct 25, 2006 2:21 pm
thanks for the advice.
if this guy cant get a 65 for me by saturday i will go the 70.
although after reading what strika said im tempted to go the 70 anyway....
MrStompy
Postby Strika » Thu Oct 26, 2006 8:01 am
MrStompy wrote:thanks for the advice.
Go with the 70. I found an added benefit of the 70 on the road, was that it made the front end settle down a lot. No more nervous twitches exiting turns. It does make it a little slower to tip in (barely) but it still holds a nice tight line once at full tilt!
As an aside, I would also encourage you to investigate a set of Metzler M3's. My recent heading of Phil's advice has thus far been intelligent, with the metzlers performing remarkably well for a road tyre. (In best Yoda voice-Impressive they are) :shock:
Postby mitch179 » Thu Oct 26, 2006 8:11 am
if you want the fast turn in back when you put on the 70 profile drop the forks a bit so its at the same height it would be with a 65 profile!
mitch179
Users browsing this forum: No registered users and 21 guests
