HELP REQUIRED.
HELP REQUIRED.
Postby L3raven » Sun Oct 01, 2006 11:04 pm
Im rejetting my L3 after ive done the airbox mod and need to know A wats the best jets to run that will give me the best proformance and B the best way to tune my carbi's. feed back would be very nice.
Pops the clutch n falls off haha!!
L3raven
Postby FrogZ » Mon Oct 02, 2006 7:36 am
raven, unless you kow someone with a dyno or exhaust reader (lambda ??) then it is all trial and error seat of the pants, plug chop (unleaded??) stuff.
When you are talking taking the tank off, removing airbox and crabs, then bowls, swap jets and reverse procedure ad infinitum unitl you are happy, it wears VERY thin VERY quick.
Unless you have finders like a spider monkey, get to a dyno. :wink:
IF you do it yourself, keep a CLOSE eye on the heat of the motor, thats your first sign of leaness and you DONT want to root your motor saving a few dollars :cry:
FrogZ
Postby L3raven » Mon Oct 02, 2006 11:13 am
Would it be saving me a headache if i took it to a pro and got a yoshi kit put through it and them to tune it?
L3raven
Postby Johnnie5 » Mon Oct 02, 2006 12:36 pm
L3raven wrote:Would it be saving me a headache if i took it to a pro and got a yoshi kit put through it and them to tune it?
of course it would save you a headache provided they were capable to do it
and of course there is far better options than Yoshi
Johnnie5
Postby aardvark » Mon Oct 02, 2006 1:25 pm
If you can get someone else to do it, it'll save you a lot of rooting around. You wont learn as much, but you wont go bald from pulling your hair out!
I have just lost 3 full days stuffing around with the carbs on my RD250LC.
I have two sets of carbs (both different model numbers), 3 sets of needles, 3 sets of main jets, 2 sets of pilot jets and 2 sets of needle seats.
Changing any one component can effect the way the others work. Although, I'm talking about a 2-stroke and not a 4.
Finally got my bike running properly last night. Turns out all of the needles I had were the wrong type.
Now the little sucker wheelstands in 2nd off the throttle. Not bad for a 250. :lol:
Postby L3raven » Mon Oct 02, 2006 3:29 pm
I'll have another crack at it, if i cant get it right then i guess i'll call a pro and let them look ait, was quoted round $250 ish for the kit and 3 to 4hours labour at $77.00 an hour.
L3raven
Postby FrogZ » Mon Oct 02, 2006 5:54 pm
Make sure you note where everything is BEFORE you start
WRITE IT DOWN
Just in case of course :wink:
FrogZ
Users browsing this forum: No registered users and 13 guests
