Engine covers and Race preping on a budget.!
Re: Engine covers and Race preping on a budget.!
Postby greenman43 » Tue Mar 16, 2010 8:01 am
photomike666 wrote:I might just purchase another set with drilled heads.
Mike, if you decide to do this, I'll be happy to buy the undrilled bolts from you.
Brian
greenman43
Postby photomike666 » Tue Mar 16, 2010 9:46 am
Brian
Ok, but they are for my 1999 CBR600, not sure they'll be the qight size for a 10?
Postby bishboy » Tue Mar 16, 2010 11:40 am
Got to get and do mine one day :roll: , might just buy some heavy duty replacement engine covers now that they are allowed, but would depend upon the cost :?
here's a topic with some good video links http://www.ksrc-au.com/phpBB3/viewtopic.php?f=21&t=24533&p=381941&hilit=lock+wire#p381941
you can also buy pre drilled bolts in either stainless or titanium (go to the race spec listing) http://www.probolt-australia.com/Home
Edit:
How many layers of carbon did you use to make the covers?
84 KX250
79 KX/KLX 250 evo project
YZ465 latest project
bishboy
Postby ZXR750 » Tue Mar 16, 2010 1:44 pm
MadKaw wrote:Nup, its because Coolant is slippery and if it gets on the track (either thru a crash, blown hose or overheating) will cause accidents...
Water is slippery too though... ;)
The glyco in coolant is supposed to be wetter than water. And I thought wet was wet.
If you can get a very small amount of coolant on your fingers rubb it together you will see how much more slippery it is than water.
Are you allowed to run DCA in the water or does it have to be just water??
Bike 93 ZXR750
05 ZRX1200
05 DRZ400
ZXR750
Bike: ZXR750
Postby simidau » Tue Mar 16, 2010 1:46 pm
The MA (Motorcycling Australia) MOMS (Manual Of Motorcycle Sport) says water only so unless the event Supp Regs say otherwise it's water only.
Check out all the racing action with Team Tiger
http://teamtiger.com.au
simidau
Bike: Honda
Postby MadKaw » Tue Mar 16, 2010 1:56 pm
Sounds like the race prep is working at Wakefield today.
Wattie has already destroyed the new rear control tyre after a couple of sessions.
He's into the 104's which should put him at the front of D grade and not to far from the front of the rest of the field come race day...
Postby Six Addict » Tue Mar 16, 2010 4:25 pm
nice one!!! the tyres could get expensive but... what about russ? :)
Postby Gosling1 » Tue Mar 16, 2010 7:02 pm
MadKaw wrote:......Bits that small are always gunna break.. especially drilling into round allen head bolts and the like with a hand held drill and vice grips.. :oops:
I figure its still cheaper than a drill press... Did 4 bikes with em.....
hand-held drill and vice grips ??? FMD mate, that's a horses arse that is !!
Get a bloody drill press, it is one of the best workshop investments you will ever make, and once its up and running, you will wonder how you ever survived without it !!
ps well done Wattie on those times - HIggsy does 1'06's on his P&M Period 5 Kawasaki !! :twisted:
Postby greenman43 » Tue Mar 16, 2010 7:17 pm
photomike666 wrote:Ok, but they are for my 1999 CBR600, not sure they'll be the qight size for a 10?
D'oh ! Maybe not, unless your CBR is running radial calipers :)
Thanks anyway,
Brian
greenman43
Postby Six Addict » Tue Mar 16, 2010 8:57 pm
thats a negatory brian :(
Postby greenman43 » Tue Mar 16, 2010 9:29 pm
Bugger.
greenman43
Postby photomike666 » Tue Mar 16, 2010 9:58 pm
Thanks anyway,
Brian
Check out Tasty Nuts, I got mine from the UK, but I believe they now have a distributor in Aus. Get serive and good products. While I was getting my caliper bolts, I got Ti allen screws for the brake fluid resivoir, much better than the stock chocolate phillips head screws.
Postby greenman43 » Tue Mar 16, 2010 10:11 pm
Thanks Mike, I knew about them, just thought I'd sniffed out a bargain :D
Brian
greenman43
Postby Supafrog » Wed Mar 17, 2010 9:24 am
My turn to be a newb...
is there certain parts that need the carbon fibring done to them? ie: is there a mystical list to refer to?
Supafrog
Postby MadKaw » Wed Mar 17, 2010 9:28 am
Engine covers that contain oil that will contact the ground in a crash...
PreviousNext
