Fri Jun 19, 2009 4:47 pm
seiko1 wrote:Gman wrote:on the note about it being a hyperdrive, it does make sense. My bike is called the millenium Ninja. You guys might recognize the name. It made the Kessler run in 12 parceps
That would be "parsecs"
CAUTION>>>>STAR WARS GEEKS ALERT<<<<CAUTION
Sat Jun 20, 2009 6:11 pm
i have the same problem with the rear brake, doesnt turn on though when i put my foot on the lever. press it a couple of times and it works. So hopefully have the same problem just in reverse
Sat Jun 20, 2009 6:13 pm
Gman wrote:It is a flux compasitor...i just got back from 2055
Did you bring back the Sports Almanac?
Sun Jun 21, 2009 2:31 am
gpxpunk wrote:i have the same problem with the rear brake, doesnt turn on though when i put my foot on the lever. press it a couple of times and it works. So hopefully have the same problem just in reverse
PS did I mention REPLACE the switch
IME when the switch start playing up it is normally either siezed on the contacts inside are stuffed.. WD40 helps but only prolongs the inevitable....
A universal type switch can be brought from Coventry's Repco for stuff all . Sometimes you may have to adapt wiring but for the cost saving who cares
Mon Jun 22, 2009 1:04 pm
seiko1 wrote:Gman wrote:It is a flux compasitor...i just got back from 2055
no i forgot but i did bring back some winning lotto numbers
Mon Jun 22, 2009 1:05 pm
i sawed through it and now the bike isn't working....hahahaha
Mon Jun 22, 2009 1:08 pm
you can adjust it. hold the switch itself and rotate the plastic nut. it might be screwed out and when you push on the rear brake peddle it's not pulling the switch piston. Needs to be tightened
Sat Jun 27, 2009 6:55 am
it's not the igniter box as that is bolted on the right hand side (rear brake side) of the bike.I am putting my money on an alarm of some sort.
Sat Jun 27, 2009 7:14 am
someone might have said this already, but def. A black box flight recorder!
Sat Jun 27, 2009 7:15 am
Just located an old Almanac........ It says it's a power enhancer......... you can double the bikes performance or alternately halve it....
It's works similar to morse code, so..... What you gotta do is.......
push the upper button three times, then the lower button three times, then the upper button twice, then the lower button four times, then the upper twice more and then both buttons together........give that a go....... just repeat in reverse to reset, or was that the other way around, can't really tell pages are faded in this old Almanac..... glad to help...
Mon Jun 29, 2009 9:15 pm
what. in. the. hell ?
