how often should chains and sprockets be changed?
Re: how often should chains and sprockets be changed?
Postby lifeofcrimeguy » Fri Dec 19, 2008 9:41 am
Bogan wrote:
Gosling1 wrote:buying a full chain and sprocket 'kit' will kill your wallet. On the other hand, buying the sprockets seperately (aftermarket), and a chain on its own, is considerably cheaper in my experience. You will need to do this soon.
You can usually pick up AFAM sprockets on this board for $50 posted, or failing that you can buy an AFAM sprocket/EK chain kit from Ron Angel Wholesale (or a distributor who can get it from them) and as long as you get standard gearing they'll guarantee the sprockets for life as long as you continue to buy your EK chains from them. There was a guy on here who could get them who I got mine through.
$50 posted :P You having a yank mate?
See here, young man,
From Walgett to the sea,
-- Banjo Paterson
LMFAO
lifeofcrimeguy
Postby IsleofNinja » Sat Dec 20, 2008 2:38 pm
Hmmm -- think a little translation issue lies here re KSRC piss pulling terminology :lol: :lol:
06 ZX10r , 95 ZX9r
07 FXST
IsleofNinja
Postby gpxpunk » Tue Dec 23, 2008 1:42 am
chains should be changed when you change sprockets, and sprockets should be changed when replacing a chain!! :twisted:
1987 GPX250R. memories
2002 ZX7R . sold!!!!
gpxpunk
Postby Stereo » Wed Dec 24, 2008 2:07 pm
I once decided NOT to change the front sprocket when I was changing the chain and I regretted it later...
The rear sprocket I reckon can go longer as it takes less wear... Plus you can keep an eye on the rear sprocket easier, providing you are not seeing a cresting wave design, or tips missing from teeth they are usually fine. (in my humble opinion)
Postby photomike666 » Wed Dec 24, 2008 2:38 pm
See here
Postby Wardy » Wed Dec 24, 2008 4:17 pm
gpxpunk wrote:chains should be changed when you change sprockets, and sprockets should be changed when replacing a chain!! :twisted:
Why would you replace your sprockets if only your chain is stuffed and vice versa.
You can visually check your sprockets for wear. You can measure the length of your chain to see if it's stretched and you can feel for tight spots.
06' zx6r limited edition
Wardy
Previous
Users browsing this forum: No registered users and 34 guests
