what fuel do you use?
Re: what fuel do you use?
Postby Frax » Thu Feb 09, 2012 1:20 pm
IIRC Bp is the only company that refines their premium to a 98oct level and everywhere else uses additives to bring their fuel up to 98oct.
Don't quote me on that though. BP Ultimate 98 is all I run in my cage and when I get a bike it's all I'll run in it.
Frax
Postby TyM2Go » Thu Feb 09, 2012 1:33 pm
well ye im a stick to the 98 bp ultimate was about to give into peer pressure into changin fuels lol
╭∩╮(︶︿︶)╭∩╮the police.
TyM2Go
Bike: Ninja 250
Postby Six Addict » Thu Feb 09, 2012 2:46 pm
95 octane on the 250... i got worse economy using 98... that and its only designer to run 95... save your sheckels for other things (booze, women, cocaine etc)
Postby born green » Thu Feb 09, 2012 2:55 pm
Strika wrote:Glen's senile don't listen to him. It's tuned to run 95. There is no benefit running anything else apart from being a wanker and telling everyone you run 98 cause it's the most expensive and therefore the best. For a ZRX rider, the guy has no fucking brains! I reckon we should make him sell the farker! He's an embarrassment to all the other cool rex riders. Like......umm....like......umm......I'll get back to you.
:lol: :lol: :lol:
2nd the 95 on a stocker.... thats all it needs... now if it was hotted up.. then, o wait its only a tiddler :lol: :lol:
96 ZX7R roady
95 tickford XR6,
born green
Postby JPaddo » Thu Feb 09, 2012 4:03 pm
98 on the 12R, was dyno tuned on it, and ignition advanced to suit. I wouldn't dare put even 95 in it. :shock: Tend to go with caltex usually.
Most people will tell you higher grades won't matter if your bike isn't tuned for it, and just go with the manufacturer recommendation.
JPaddo
Postby hoffy » Thu Feb 09, 2012 5:01 pm
I use strictly Ampol unleaded..
Postby h.b.bear » Thu Feb 09, 2012 5:08 pm
i use bp because its real cheap but it takes a long time for the little bastards to fill a tank :roll:
h.b.bear
Postby Strika » Thu Feb 09, 2012 5:09 pm
Lets start an argument. its compression ratio more than timing which determines best octane rating .
Postby born green » Thu Feb 09, 2012 5:24 pm
Strika wrote:Lets start an argument. its compression ratio more than timing which determines best octane rating .
Bugger marty.... u just confused me... i thort it was both :shock: :shock:
96 ZX7R roady
95 tickford XR6,
born green
Postby Gosling1 » Thu Feb 09, 2012 6:35 pm
Strika wrote:....Lets start an argument. its compression ratio more than timing which determines best octane rating......
stop being sensible !
Postby TyM2Go » Thu Feb 09, 2012 6:38 pm
well from what ive read the higher the compression ratio the higher the octane rating u can run it on for optimum performance as for ignition timing dont know a whole lot on it but if u set the ignition time for a later period so all the fuel gets burned up before reaching the top dead centre point would
so ill go with compression ratio even tho they both play some what equal parts i could be wrong
i dont know much about it explain your point of view so i can better understand it
TyM2Go
Bike: Ninja 250
Postby Gosling1 » Thu Feb 09, 2012 6:39 pm
google *detonation* - that will give you the best explanation :)
Postby MAXUMIS » Thu Feb 09, 2012 7:32 pm
LOL i think it's both but don't go off US style of fuel ratings as they are done in "MON" not "RON" so all im trying to say is our 98 is there 91 :twisted: :lol: :lol:
life starts at 200 kph!
MAXUMIS
Postby ninja250r81 » Sat Feb 11, 2012 4:55 pm
this might give people an idea on how the different fuels need different tuning.
http://www.ozgarage.com.au/season1-vide ... -fuel-test
additives inhibit what the fuel is designed to do
http://www.youtube.com/watch?v=Vj_21dikYR8
ninja250r81
Bike: Ninja 250
Postby Gav » Sat Feb 11, 2012 5:08 pm
TyM2Go wrote:well from what ive read the higher the compression ratio the higher the octane rating u can run it on for optimum performance as for ignition timing dont know a whole lot on it but if u set the ignition time for a later period so all the fuel gets burned up before reaching the top dead centre point would
Are you really interested in this ...come on mate this has to be a gee up
Gav
PreviousNext
