Tyre Wear
Postby Jonno » Tue Aug 09, 2005 3:38 am
photomike666 wrote:Just replaced front & rear with Dunlop 220s, $382 fitted and balanced.
So far done 250k, half of which in the wet. Confidence is good, haven't exactly pushed them yet though.
The old tyres hung in for a good while. Got 15,000 from a Pirelli GTS rear and 30,000 from a Metzler ME1. I mostly commute to work and play twisties on the odd weekend.
wow, I can only dream of such milage. :roll:
Postby aardvark » Tue Aug 09, 2005 9:02 am
photomike666 wrote:and 30,000 from a Metzler ME1.
:shock:
30,000 kays??? You're kidding right? Surely you mean 3000 kays?
30,000 kays?????? Mate, you're supposed to replace them when the black stuff runs out!
Postby photomike666 » Tue Aug 09, 2005 11:25 am
It still had 2mm legal on it, although it was a bit square. My commute to work is 30 mins freeway and 15 mins high street. Makes for good tyre wear and boring riding
Postby Jonno » Tue Aug 09, 2005 12:49 pm
photomike666 wrote:It still had 2mm legal on it, although it was a bit square. My commute to work is 30 mins freeway and 15 mins high street. Makes for good tyre wear and boring riding
Got helium in them? :lol: man thats just unbelievable. Still good going anyway :shock:
Postby Barrabob » Tue Aug 09, 2005 12:53 pm
Ardvark has the bead popped properly right around the rim?
I have seen them not qite fitted right and they wobble a little on the rim or has the wheel weight fallen off, take it back if it isnt quite right.
Barrabob
Re: re: Tyre Wear
Postby HemiDuty » Tue Aug 09, 2005 11:23 pm
Date: 12 July 05
Tyres: Bridgestone soft compound superbike slicks. (Off with old Diablo Corsas - No more street tyres for me!)
Front: 125/600/17 80% rubber
Rear: 190/660/17 50% rubber
2 sessions at QR so far, actually showed faint signs of wear in that 45 or so mins of tracktime. Hoping to get 3 full trackdays out of rear tyre, should get at least twice that from front.
Pontikat wrote:snippity......Fitted second hand set of Pirelli Diablo's (thanks Hemi) at least 60% left in the middle, they reach temperature really quickly then front goes squirmie when pushed hard & rear likes to rip compared to the 012 SS but i feel more confident with them even though I know i'm not as quick as the Bridgies 012 ss
Cheers Brett
What pressure you running Brett? I know it's bad for longevity, but they do seem to like lower pressures. They used to be best at 30psi front and rear at the track, I reckon maybe 32 front 33/34 rear for road would help? Mind you your 9 would make 1 or 2 more horsepower than my 7...... 8)
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
HemiDuty
Postby aardvark » Wed Aug 10, 2005 12:05 am
beryl wrote:Ardvark has the bead popped properly right around the rim?
Buggered if I know... it doesn't feel like it's wobbling, more like the bars are pulsating in my hands. That probably doesn't make any sense, but it's the only way to describe it. And I've never felt anything like it before.
I did a track day at Phillip Island with it like it, so I really can't be bothered getting it checked. :lol:
Postby aardvark » Fri Nov 25, 2005 11:43 am
Initial post updated.
Postby smek » Fri Nov 25, 2005 9:30 pm
Is it anything like this ?
with mine when cruising sometimes I can feel a vibration in the left bar, then the right bar, left, right, left .. well you get the picture.
it probably lasts a second per side. Could call that pulsating.
slightly odd, but not something I'm worried about.
smek
Postby sneakypete » Fri Nov 25, 2005 10:22 pm
i may be biased jason, but stick with the Bridgies...
1992 Suzuki Across (GSX250)
1993 Honda CBR600
1995 Honda RVF400 (race bike)
1999 Kawasaki ZX9R
2005 Kawasaki Z1000
sneakypete
Postby aardvark » Fri Nov 25, 2005 11:53 pm
smek wrote:Is it anything like this ?
Yeah, something like that. I've worked it. It seems the front tyre is as badly scalloped as the rear. A little more pressure in the front and some slight softening of the suspension settings has made it less apparent.
cambo: version 2 wrote:i may be biased jason, but stick with the Bridgies...
I may go back to them now that I'm not using the bike as my daily commute. But I do like the mileage (kilometreage??) I am getting out of the Michys.
Postby Nanna10r » Sat Nov 26, 2005 3:36 am
So Jas your getting better milage out of Powers then the Bridgies ?.
I also updated initail post But a Certain bloke has just recieved a special order of Shinko 003 (both soft n supersoft) at the unbeatable price of under $300 a pair fitted.
So guess whats going on "tiggr" next week. *I wonder if my half used front 012 SS will work with a Shinko 003 Rear ? ....... hmmmmm .
Cheers Brett
Nanna10r
Postby MadFab » Sat Nov 26, 2005 9:46 am
why do some of you imbeciles continue to mix tyre brand or profiles ?
do you honestly believe that some inbred retard from goodna is smarter than the tyre manufacturers.
you fuckwits deserve to fall over!
fab
p.s. pontikat you are doing something wrong if you cannot keep up with a fruitloop on a zx12!
MadFab - New and improved.
MadFab
State: Overseas
Postby Nanna10r » Sat Nov 26, 2005 9:58 am
So how's Perth Fab ?
Cheers Brett
Nanna10r
Postby MadFab » Sat Nov 26, 2005 10:00 am
have a nice life ............loser
fab
perth is great cause you aint in it !
MadFab
State: Overseas
PreviousNext
Users browsing this forum: No registered users and 16 guests
