IF they are really kero and nothing else added in there, I don't see why not.Mizz ZZR wrote:And, if that Aus Export stuff is just pressurised kero, can you see any problems using it on your chain? (I'm thinking spray is easier than a soaking rag/toothbrush).
Mizz ZZR wrote:While we're at it, does anyone have any sensational ideas on how to clean your front sprocket?
Mine is covered with a side cover and has a sensational quantity of goo oozing out underneath it.![]()
Johnnie5 wrote:
recently when i had the ZZR250 took the sprocket cover off went to the self serve car wash with a $2 ($1) can of degreaser and thankful for the centre stand was clean and spiffy and looked like a brand new chain and sprockets in no time
Johnnie5 wrote:
on the centre stand brush and in gear, keep fingers away from hurties
later into top gear lots of degreaser and a liberal dosing of the hose and all clean
make sure bike is stable as dont want it running away
i wouldnt worry too much about a once off with degreaser and the hose
Stereo wrote:....The safe and only way to do it is to put the bike in neutral, with the engine off and turn it a little bit at a time..... Its safer and you do a better job....
Users browsing this forum: No registered users and 22 guests
