Battery question
Postby mike-s » Fri Aug 25, 2006 4:13 pm
bonester wrote:the only time it didn't want to start was in Tamworth after it spent the night out in sub-zero temperatures-bike was covered in ice and the starter wound over too slow to start. I ended up waiting for the bike to defrost and shorted the starter relay to start it.(with the ignition switched on) :D
had that happen a few times to me too. Once i couldnt leave work after a nightshift for about 30 mins as i had to let it defrost a bit, then roll started it down the service road at the side of my work. The only problem was it was a bit too cold and i had to do a duckwaddle on the bike and rollstart it. Nightshifts after that i just kept the bike in the loading dock :-)
Postby Neka79 » Fri Aug 25, 2006 7:06 pm
gotta get me another bloody battery..when the time is right...and the bike is rego'd...and im licenced...
Postby mrmina » Sat Aug 26, 2006 12:38 pm
supercheap auto m/c batteries $60
Postby Johnnie5 » Sat Aug 26, 2006 6:20 pm
i grab my batteries at Apollo , they always have em in stock
usually buy a Toplite battery which from what i have heard is the yuasa battery under another name usually $77
Johnnie5
Postby bonester » Sun Aug 27, 2006 5:50 pm
Supercheap batteries don't come with acid- you purchase that separately. :shock:
bonester
Postby mrmina » Tue Aug 29, 2006 1:48 pm
bonester wrote:Supercheap batteries don't come with acid- you purchase that separately. :shock:
mine came with two bottles.
Previous
