Duane wrote:Bump starting FI works.
EFI maybe not
mines a bitch cos wen u turn on the ignition, u can hear the fuel pump prime....without power, u can roll start the farker all day & she wont go...
EFI maybe not
Greenblood wrote:[
The problem is I need to have the bike spinning in gear to prime the oil
in the motor ( it has a kit oil pump ) with the egnition off. For 20 to 30
seconds, after a while without running ( bettween races or ride days).
Strika wrote:Greenblood wrote:[
Man.....How much power is that thing putting out????? Kit oil pump?What else has it got??????
SocialSecurity wrote:just curious, what gear are you trying to start it in?
you never use first when push starting a bike, 2nd is usually the go... but if its still too hard, maybe try 3rd?
SocialSecurity wrote:could be dangerous
what are you using for a power supply? and what size cables?
SocialSecurity wrote:as in it could burn out the starter motor
do you have a multimeter?
use it to measure voltage at the battery terminals while trying to start the bike, then measure it at the starters terminals while trying to start it to see if there is any voltage drop
SocialSecurity wrote:basically measure the voltage at both ends of the cables, at the battery and at the motor (which ever terminals the wires are connected to)
if there is a voltage drop then it means the cables are too small
if you have say 10v at the battery while cranking but only 8v at the motor while cranking then thats a lot of juice not getting to the motor. in that case, try using two runs of the same cable so the current has double the cross sectional area to pass through. also try and keep the cables as short as possible.
if theres no drop then uhmm.... bugger eh
Users browsing this forum: No registered users and 14 guests
