by mike-s » Thu Aug 05, 2010 10:39 pm
Oh dear, im glad i wasn't drinking anything while reading the GSX vs EH comment, otherwise i'd be cussing while cleaning my monitors.
Picked up the new gasket today. Also regarding retensioning, if I reused the old gasket again and it happens again it's not just an oil leak, but the oil getting driven OUT by the cylinder loosing compression, thusly loosing power like it is right now. Which would go a long way to explaining why it's having a bit more of a hard a time keeping at anything over 115km/h or 8,500rpm (whichever is the greater) when it was previously happy humming along at 125~ish with more umph to go (i didn't want to push my luck too much, given it takes a lot more time/distance to build up the speed than the 900 does). The construction of the new gasket is vastly different to that of the old (part numbers being superceeded and all that). The old was predominantly a single metal sheet with a thin layer of a soft gaskety material either side, the new one is two sheets of metal with a thin layer of the soft stuff between them, Hopefully this new construction helps it in the long term.
<side story>I took the 900 out to pick the new gasket up today, amongst other things i had to do today. Got to the bikeshop (name omitted), obtained the gasket, got on the bike to go home. Tried to start it, and would you believe that the f*ing thing lost ALL power on me and just wouldn't work. No blown fuses (i today discovered an extra fuse i had no idea it had previously) and all the help that the service manager would give me was load testing my battery to make sure it hadn't dropped a cell or something equally arse-achish (i would have gone and bought one there if it was). His other suggestion was "book it in for a service" as he walked away, great, thanks buddy. At this point ego and determination to not let this (or the f'wit service manager) get the better of me crept in and prevailed. For Christ sake i wasn't expecting them to fix it for me there and then, but perhaps giving me a couple of suggestions would have been nice.
Thank god i had the (crappy) toolkit that the bike came with, Went as far as taking the tank off, and 1/3 the plastics and reseating every single connector to make sure it wasn't the source of my lack of electrons. Fast forward an hour and a half and i found it was the freaking high amperage cable from the battery through to the distribution point/relay that had upped and shat itself and only worked when it was laid out in a certain way and wouldn't even consider wirking if it was angled in any other manner. Got her started, crept home and threw her in the garage as something else to waste my time on tomorrow.</sidestory>
Yet another reason to add to the list why i only buy oem parts, riding gear/accessories from these guys & don't bother going near the service centre.
