Thu Feb 02, 2006 2:59 pm
I have this audable clunk coming from my rear wheel, u can hear it every revolution or there abouts, i cant entirely pin point it but sounds like lhs rear wheel...
i can feel it through the lhs foot peg aswell when coasting with the clutch in .. cant feel it under engine braking or acceleration..
any one got a remedy ?
EDIT: ok no tight spots in the chain.. and its doing it once per revolution...
Thu Feb 02, 2006 3:19 pm
Cactus sprocket?
Wheel bearing?
Loose sprocket Nut/bolt?
Thu Feb 02, 2006 3:21 pm
Sounds spooky whatever it is -
Hows the back cog look? Got a centre stand? You could put it up on it and let the bike idle in first, then get down and have a good look/listen around it. I wouldn't ride it while it sounded like that myself.
Thu Feb 02, 2006 3:37 pm
i have a rear stand thats what ive had it on checking it out, rear sprocket looks fine to me ... cant see a problem with it but ill go inspect it !
Thu Feb 02, 2006 4:12 pm
checked out the sprocket and it looks fine .. checked most the links around where it clunks and couldnt find a stiff one ...
might just ride it til it fixes itself haha j/k
Thu Feb 02, 2006 4:13 pm
sound like wheel bearing, have you lubed rear wheel assembly, sometimes dirt or bearing failure can cause that clicking sound.
It happened to a steering head bearing on my dirt bike once, and it made that clicking noise when I turned the bars from left to right.
I replaced the bearing and it was fine, it was very dirty, lube would proly fix it though on such a new bike though.
Fri Feb 03, 2006 11:37 am
hmmm doesnt appear to be doing it anymore... took it for a spin today, no noise and i couldnt feel it through the peg either, if it comes back ill investigate it further but for now im gonna enjoy riding the thing
Fri Feb 03, 2006 11:01 pm
I had a similar thing happen on a car once, turned out to be a piece of chewing gum on the tyre! Took me ages to find it too......
