Switch to full style
Post a reply
Lever height
Tue Apr 05, 2005 2:46 pm
Hey guys, due to my big dopey feet, i need to lower my gear lever so i can change up without lifting my whole leg.
I don't wanna make any stupid mistakes like someone else
ahem... ment... ahem
If i increase the rod length.
Will that have an affect on the shaft movement?
Any advice will be much appreciated.
Cheers, Vince
re: Lever height
Tue Apr 05, 2005 3:26 pm
All it will do is change ya lever height,so go for ya life.
Stu
re: Lever height
Tue Apr 05, 2005 5:22 pm
mate, after a really good effort on my own... :shock: :oops:
i can say for sure that it will be fine.
ment
re: Lever height
Wed Apr 06, 2005 12:47 am
By increasing the rod length do you mean making a longer rod? or if you are just adjusting it, it will be fine. Making a new one too long may make the lever/clevis and rod have longer, shorter throw or just does nothing might be the result.
re: Lever height
Wed Apr 06, 2005 1:37 am
only gonna adjust it a little.
i'm 6foot 4 which means the leaver is in a realy awkward position.
shouldn't take much to make it comfortable though.
re: Lever height
Wed Apr 06, 2005 1:41 am
Go for it, I had to do that to the gear lever and rear brake lever on most of my bikes.
re: Lever height
Wed Apr 06, 2005 8:57 am
What about some adjustable rear-set's?
Re: re: Lever height
Wed Apr 06, 2005 1:44 pm
NovaCoder wrote:What about some adjustable rear-set's?
thats probably the least dodiest solution
re: Lever height
Wed Apr 06, 2005 2:30 pm
just unbolt the gear leaver and pull it off and shift it a notch or 2..
That's how I was shown to adjust mine by the guys at the superbike school.. worked a treat...
re: Lever height
Wed Apr 06, 2005 2:59 pm
Yep as was said adjusting it will raise or lower the lever
mario
Post a reply
