Switch to full style
Post a reply
Small leak in stator cover....
Tue Feb 27, 2007 8:58 pm
Hi guys, I have a small leak in my stator cover.... Im not sure what its made of.... can a stator cover be welded?
If so, can anyone here do it?
Is it ok to remove the stator cover or will it piss oil all over the place? When I re-attach it, do I need to use a torque wrench?
Tue Feb 27, 2007 9:20 pm
well is it leaking from a gasket or has it been bitumen surfing????
if its leaking from a gasket get a new gasket and tighten it but you dont have to break the socket doing it it is alloy you are working with so medium tight all round with a new gasket and its all good.
if it has been bitumen surfing i got one off ebay brand new for 150 and it got here from the states in a week.
Tue Feb 27, 2007 9:55 pm
Araldite is your friend :wink:
Tue Feb 27, 2007 10:07 pm
umm ull need to dump the oil..or ull dump it when the cover comes off...maybe.,..in fact im sure u will..
Wed Feb 28, 2007 10:28 am
Definitely drop the oil before you remove the stator cover. Yes they can be welded if the cover is cracked. I wouldn't use araldite myself... and if you're going to get a new one, get an aftermarket as the stock one's are weak as piss. -J.
Wed Feb 28, 2007 10:58 am
I did the stator gasket on the honda last month, yes to dropping the oil. Fairly easy, took a bit of work cleaning off the old gasket to get a smooth surface.
Wed Feb 28, 2007 6:49 pm
should also add that if you are talking about the 6r theres something screwed inside thats held on by torx screws so u will need a funny bit to remove this.
I had someone else do it for me and watched his torx bit snap in half so there in there nice and tight.
Wed Feb 28, 2007 8:26 pm
pfft, you can get a set of torx security bits from dick smiths for $10. :-)
Sun Mar 04, 2007 7:50 am
Sorry, its for the Gixxer, and it has been bitumen surfing.... It leaks the tiniest bit of oil from a crack on the cover.
Steph didnt notice the problem until a few months ago because the previous owners painted over it, and the heat eventually peeled off the paint, and then it started leaking....
It must only leak when the engine is pressurised because it doesnt leak when standing still.
Tue Mar 06, 2007 12:36 pm
oh well thats an even easier fix...just paint back over it!!
Tue Mar 06, 2007 4:21 pm
Try this place
http://www.easyriderimports.com.au/opps6.asp
Tue Mar 06, 2007 5:19 pm
actually u should be able to get ummm NRG or sumthin?? there in amcn etc..good for race bikes, super strong..they dont make em for my bike tho ...
Wed Mar 07, 2007 6:19 pm
So what did you do stereo because mine has sprung a leak now after it fell over in the driveway, did you bog it, replace it, muffler putty it or buy a new one??
I have a rashed secondhandy about here somewhere but i think i will bog and order a nrc.
Wed Mar 07, 2007 8:50 pm
Stereo wrote:....It must only leak when the engine is pressurised because it doesnt leak when standing still.
It leaks when the engine is running because the oil is hot and thin, and is reaching the level of the crack as it runs around inside the motor. It doesn't leak when standing still because its all down in the sump, nowhere near the crack in the cover.
You could use some Devcon to fill the crack, its like an aluminium epoxy resin that works great on crankcases, engine covers etc.
Wed Mar 07, 2007 10:35 pm
I just used some silicone on the outside of mine and do some more in the morning just to make sure.
I fall over in a parking oppsie every six weeks or so and cant find this crack without the engine running its so fine, time for the heavy duty engine casing recommended for kawasakis. new_Eyecrazy.gif
Post a reply
